Start-up noise / White smoke
If you end up having to replace the head gasket, make sure you get the valves properly adjusted as well and make sure everything is seated/sealing properly. May as well knock out all potential areas of problem at once. Put in new seals as they're pretty cheap minus the cost/effort of labor which you'll need to do regardless.
Originally Posted by JUSTINTHECOASTIE' timestamp='1460310284' post='23933767
Not sure if that discolor due to the paper towel or whatever but your water sample looks as if it has oil in it
Car is just about to turn 70k actually.
In regards to the valve adjustment. I had the valves adjusted around 66k. It was just a precaution as I bought the car with 62K miles. The valve adjustment was done by Elevated Automotive in Bel Air, which is pretty reputable.
Jeremey (owner) even said it was one of the best condition S2000s he has seen. I feel if the head gasket was leaking, he would have caught it then?
Furthermore, the valves were still in spec.
I will clean the block and keep an eye on it. Hopefully its not serious.
May want to try one of these kits, to test if the head gasket is blown out.
https://www.youtube.com/watch?v=QA7K...&nohtml5=False
Well I just had the free oil kit from Blackstone labs sent. I will send my oil to them for analysis (see if there is coolant mixed).
I will also pick up a compression test kit and get the compression numbers. I think these two things should suffice.
Anyone have a compression kit they recommend?
