Staggered vs Non-Staggered
Originally Posted by F20AP1' timestamp='1327691249' post='21358823
[quote name='LeonV' timestamp='1327690833' post='21358805']
As you increase rear tire size while keeping fronts constant, you tend towards understeer. Vice versa for increasing front size. In a nutshell, this all has to do with the cornering capability of the tires. Smaller fronts will limit your lateral acceleration in the front, thus you understeer at the limit. With this in mind, the car was engineered with a certain balance. Production cars will 99.9% of the time lean to the safe (understeer) side of the handling spectrum, at least with regard to steady state cornering. Power oversteer and throttle-lift oversteer are completely different topics.
Making just the fronts bigger will move handling tendencies to oversteer in steady cornering. While making both front and rears bigger will increase the total lateral load capability of the car, there will be more steady state understeer when compared to a "square" setup.
FWIW,
Leon
FWIW,
Leon
As a RWD car that the rear of the car is generally wider than the front (very much like the s2000) you always ALWAYS want to fit as wide of a tire to maximize cornering grip so since the rear is wider why would you limit yourself to a 255/40/17 all around when u can easily do a 255/40/17 front and a 265/40/17 rear or a 275/40/17 rear, why not a 285/40/17 rear e.t.c... my point is why would you ever limit yourself to a "square" or non-stagger setup to me it's a compromise and most people do it so they can easily rotate tires at the track for better tire wear conditions... catch me? The rear of our car is wider than the front.. tuck a wider tire back there like it was designed to do... plus simple physics dictates more weight shifts towards the rear of the car during acceleration cornering loads...
[/quote]
Very true... Your opinion is also supported by fact... there was no argument by me intended... infact your absolutely correct... I'm just simply stating opinions based on my experience/physics major that's helped me come to the conclusion in which I have stated earlier... No pun or harm intended on your comments because, yes indeed they are supportable facts...
maybe it would be better to explain how to tune with sway bars... when you setup a car for the track you adjust ride height dampening pre-load and everything else you need like alignment and what not... get it to the point in which your comfortable... let's just say you go to another track or you want to "tune"... maybe you need more bite out of your front end or maybe your front end is pushing wile going into a turn so you would adjust the sway bar rather than compromising your suspension dampening characteristics and what not then you would A: adjust the sway bar to a stiffer setting or B: adjust it to a softer setting, which is why when u buy a sway bar they tell u to put it on the middle setting so you can tune it how you like... there are several other factors but that should be sufficient... but definitely they shouldnt be to adjust the characteristics from a stagger to a non-stagger setup... and those "national champions" your talking about... they probably run certain classes in which the modifications are limited or restricted.
Originally Posted by LeonV' timestamp='1327692051' post='21358869
[quote name='F20AP1' timestamp='1327691249' post='21358823']
FWIW,
Leon
FWIW,
Leon
[/quote]
[/quote]
No harm done, but do note that I offered no opinions whatsoever, just the facts. Do with them as you wish.
Originally Posted by F20AP1' timestamp='1327692313' post='21358883
[quote name='LeonV' timestamp='1327692051' post='21358869']
FWIW,
Leon
FWIW,
Leon
[/quote]
[/quote]
[/quote]
Thanks for the opinions and advice everyone. You've all been very helpful.
I'm going to settle on getting a staggered setup on stock suspension. I will be looking to purchase coilover suspension later on in the year as well - looking for something that is a good compromise between street and track. I want to lower the car to make it look more aggressive but I am not pursuing the "slammed" look. If anything, 1 finger gap is good.
I'm probably going to get a set of 17x8 front and 17x9 rear Enkei RPF1's. Tire sizes will probably be 225/40/17 front and 255/40/17 rear. Should I do 255/35/17 in rear instead?
Also, does anybody know whether or not I will rub?
The hardcore advocates of large front sway bars are autocross guys. Here's how it originated. In stock class, they're only allowed two mods. The car on hoosiers lifts a rear tire, so they use a GIANT front sway as a band-aid fix. The other mod they do is shocks matched to OEM springs valved specifically for autocross.
Over the years, the FSB recommendation spread throughout the community, and IMO, is complete misinformation. It's so prevalent that R&C almost universally recommends it as a mod. Here's the thing. Myself and virtually all S2k Challenge (track) drivers DO NOT use aftermarket sways, or use a balanced set of sways, rather than just a giant front and a tiny or no rear.
Autocross cars are also set up to have ultra fast turn-in response (slow response is often perceived as understeer, when its really just the suspension not being loaded) and understeer like pigs in static load turns like sweepers and freeway onramps. I'm talking worse understeer than a STI.
Unless you're comfortable with what most people would consider a loose rear, I would recommend you stay staggered. Personally, I think everyone should learn to drive the car with a non-staggered setup.
Minus ViperASR, everyone who has responded has no significant amount of driving experience at the edges of the s2000.
p.s. the fastest state of static cornering in a stockish s2000 is with 6-8 degrees of slip angle depending on tire (in other words, slight oversteer)
I agree with psychoazn.
Going to a non-staggered setup will add weight to the steering, and make it feel a bit slower, since there is a larger footprint than before. I noticed this immediately when I went from 205's to 255's.
I prefer non-staggered tires so I can rotate tires front-rear, and to add grip. In a car that is so underpowered, it doesn't make too much sense to me to put tires much wider than 255 in the back.
-Connor
-Connor
To the op wherever you look in the world either at the top level of motor sports or in cars designed with no limitations you will usually find staggered sizing. the LMP team for Acura was non staggered because of tire selection, once a proper tire was developed for the front they went back to staggered.
I personally like the staggered look better and I find the overall handling is much better, you can start tuning for the last 10% and turn the car into junk otherwise which is what alot of people have done with non stag setups. I've had a few cars that should have had a massive grip advantage spin off the road behind me because the limit is so narrow like that. I was actually fully setup for non stag at one point and I had my first ever spin off track, luckily I happened to be on a deserted road but that was the final straw. Since I went back I have had a much more enjoyable car overall.
It has it's place but the number of changes and the type of changes are more race car than street car.
My personal opinion is that the car was designed with non-staggered tires, and then staggered before final production for safety reasons. Your average consumer, including 98% of this board, cannot properly address oversteer (see all the "snap" threads, etc). 205/225 going to 215/245 and then 215/255? Coincidence? I think not.
Long story short, the first mod I did for my STR AP1 was 255's all around on stock suspension. We did an autocross test and tune on a fairly fast course and found the car was very tail happy the faster the turn/transition. Multiple experienced drivers in my car and everyone with the same opinion, it was difficult not to spin the car at speed. The band aid fix that weekend was to disconnect the rear bar.
Before the test and tune, I had no idea just how dangerous the car was in that condition. Driving on the street and highway I would have never known just how loose the car really was...until say, I needed to do an emergency lane change or took a corner a bit too fast. The car WILL want to spin and even though I consider myself a skilled driver, I don't want to have to deal with a spinning car on the highway. Now that I have increased the roll stiffness up front, I have reconnected the rear bar.
My point is, just know what your getting into when you go non-staggered. Unless you make other changes, you are making your car less safe on the street. But you may never know it until a situation arises and it's too late.
I don't think the safety aspect gets emphasized enough in these staggered vs non-staggered threads.
