SRS Light Bypass AP2
Old 04-17-2009, 04:45 PM
Slows2k's Avatar
You removed the drivers airbag = there will be a trouble code stored. It's stored in the separate SRS control unit.
2 stage inflators have a different resistance and wiring than single stange.
Measuring the resistance of a airbag can be asking for trouble, as some meters apply current to a circuit to do this. You'll find out when the bag deploys in your hands.
Old 04-17-2009, 04:50 PM
mikegarrison's Avatar
Good point about NOT sticking tester probes onto an airbag.
Old 04-17-2009, 04:53 PM
Slows2k's Avatar
Unrestrained airbags will chase you around and do some damage, deployed one today actually.
It only went about 6 feet in the air before gravity took over.
Old 04-17-2009, 05:06 PM
urBan_dK's Avatar
I hope my little multimeter wasn't applying enough current to deploy the bag, that would seem very extreme since I'm sure it's not a small amount of current in order to deploy it in the first place. (Aside, how could you measure resistance without applying a bit of current? My mind tells me it's impossible...)
Thanks for the info. I'm not really closer to the solution, since I know now there have been AP2's that can bypass the SRS light with a 2 ohm resistor. Must be operator error...
Old 04-17-2009, 07:31 PM
Did it blow up in your face? Then I guess it wasn't.
Old 04-17-2009, 08:01 PM
urBan_dK's Avatar
No it didn't, but to be accurate how do you know it couldn't have at the current it was producing...maybe I was just lucky?
Anyway, its all irrelevant. I'm safe, and I know how much resistance it has
Old 04-18-2009, 12:27 PM
S2Sick's Avatar
Did the resistor that came with your hub come on a plug or is it just the resistor?
Old 04-18-2009, 12:42 PM
urBan_dK's Avatar
It was a resistor attached to a fuse so it will "blow" like a normal airbag in a crash so the SRS module doesn't get fried.
Doesn't plug in, just a wire. It needs to be soldered into the connector or something.
Old 04-18-2009, 01:21 PM
Slows2k's Avatar
The SRS unit would still have to be replaced if you did get in a collision. The impact sensors are built into the SRS unit on 00-05 cars and even without a bag attached the sensor will trip in a impact.
Tmayne124
01-02-2015 03:09 AM
rosodigital
10-21-2013 04:09 PM
r8byb
Member S2000 Classifieds and For Sale
02-21-2011 12:00 AM
Lttakas
10-16-2009 12:46 PM
killerbee_vr6
02-17-2008 01:02 PM
Quick Reply: SRS Light Bypass AP2
