SRS Light Bypass AP2
I've got a Momo hub with a 2 ohm resistor included that is supposed to prevent the SRS light from coming on.
However, it doesn't appear to be working on mine. I even did the SRS reset procedure and wasn't able to clear the light even with the resistor in place.
My question is if the AP2 SRS system is enough different that the 2 ohm resistor isn't enough? I know the AP2 has a two-stage airbag versus one stage with the AP1, but there are still only two wires going to the airbag itself.
I measured the resistance of the airbag removed from the car and it was actually only .5 ohms between the two wires. Is this my problem?
Thanks for any help/advice!
Originally Posted by Gigdy,Apr 16 2009, 04:27 AM
2 ohm worked fine for me. Make sure it is plugged in correctly then try the srs reset again.
Originally Posted by mikegarrison,Apr 17 2009, 09:13 AM
I wouldn't overwork this problem. A little piece of black electrical tape will solve your issue.
Originally Posted by Gigdy,Apr 17 2009, 10:26 AM
The works bell.
Originally Posted by urBan_dK,Apr 17 2009, 10:47 AM
Please elaborate...are you suggesting I block the SRS light from behind the instrument panel? Is there still a code visible on the ECU or is it stored in the SRS module?
I'm pretty sure the ECU is not tied into the SRS light in any way. My SRS light has been on for almost three years now, ever since I installed the race seats, harnesses, and roll bar.
