SRS light on after soft top install
What's up guys got a bit of a problem that I can't figure out, this weekend I replaced my soft top so I had taken out all of my interior, installe new top and put back in all the interior and seats and made sure to plug in all the sensors under the seat and none of them seem to be damaged
Any reason why the srs light would be on? I've reset the battery and nothing!
Also my passanger side speakers stopped working after the soft top install and have no idea why, I did remove the roll hoop tweeters and the harness (2007) but I doubt that would of triggered it
Any suggestions or any help at all would be appreciated!
Perhaps the same thought as previous post, but the seat belt retractors are on the inside of the roll hoops, with connectors to them nearby.
If you know how to check SRS blink codes, drivers open circuit is 3-1 and passenger's 4-1 (assuming they are still the same as mine.) I would check the code anyway, before diving in too far.
If the key was turned on at any time while something was unplugged (seats, retractors, etc), it will set a code.
The code can not be cleared via battery disconnect, it must be written out.
Do that first and see if it comes back on.
I just reset mine yesterday following this procedure: http://www.honda-acura.net/forums/do...srs-reset.html
Majestic Honda
07PAZ-001010A SCS SERVICE CONNECTR $12.43
http://www.hondaautomotiveparts.com/
I bought one earlier this year.
Hawkeye_AP1
06-01-2014 05:26 PM
