SRS code 12
Old 06-09-2011, 10:30 PM
MrChoi's Avatar
Default SRS code 12
i did a little digging around and later found that i have a SRS diagnostic code 12. anyone know what the code 12 is? im finding a few things on the web such as low battery or bad ground.
SRS light came on a few weeks after i installed a trailer hitch.
any ideas people?
Old 06-10-2011, 04:11 AM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
If you mean code 1-2 its the drivers airbag.
Old 06-10-2011, 06:32 AM
JEEBS's Avatar
How do you find the diagnostic code. I had my SRS light come on as well.
Old 06-10-2011, 03:25 PM
MrChoi's Avatar
ok, any idea what the problem is? my steering wheel and air bag is all stock and has not been worked on.
Old 06-10-2011, 03:27 PM
MrChoi's Avatar
on your odb2 port jump the leads #4 and #9. turn on ignition and read the blinks.
http://www.vehix411.com/category/airbagsrs/page/5/
Old 06-19-2013, 02:18 AM
Martin_VTEC's Avatar
Is this problem solved? I have the same SRS error
Old 06-19-2013, 08:46 PM
MrChoi's Avatar
The clock spring had a bad wire. Replaced it with a new one and the problem was solved.
Old 06-20-2013, 11:02 AM
Delta_lima's Avatar
What do you mean with the clock spring ?
Do you have a picture ?
Old 06-20-2013, 08:53 PM
MrChoi's Avatar
Steering wheel clock spring.
Old 06-20-2013, 11:14 PM
Thank u, how did you found out ? There isn't a lot to find about this error code.
And was it for a S2000 ? Because I haven't seen any trailer hitch on a s2000
Is this clock spring in the steeringwheel or behind the steeringwheel on te steering column ?
Is it number 9 that you replaced :
Or is it in the airbag ? number 1:
Quick Reply: SRS code 12
