Squeeky noise coming from rear.
I have a squeeky noise coming from my rear passenger side. I don't think it is my shocks because the ride is not bouncy. I have Eibach springs and stock shocks. Could something just need lubricated? Please Help.
Thanks.
Thanks.
I've got the same issue and I just have the stock suspension. I took a mechanic for a ride and he said it needed some lube in the suspension bushings. I thought I had a much bigger problem. I still haven't gotten to it yet so I can't say if he was right or not...
I had a similar problem. The hub area where it meeets the axle might need to be lubricated. Also check under the CV joint boot and make sure that is also got plenty of grease and make sure there is no rust around the hub etc.
Mine did this on the drivers side rear, and it didnt matter if I was in gear or not, or if I was on the brake or not
Thanks for the replys I will have to take it to see if they can lubricate those parts. It's not really loud but it's getting really annoying. I just hope its nothing serious.
I just had the same exact problem checked at the dealer. They told me the rt axle nut needed to be re torqued.
I just got the car back but it seems to have cured the problem, no more noise.
