The squeaky wheel
The squeaky wheel
Right rear has a warbling high-pitch squeak. Trying to figure out what (and where) is causing it so that I can fix the problem. Doesn't seem to become apparent until I've drivin' for a bit. It started a couple months ago and got progressively worse. I was gone for 10 weeks (Army stuff) and just drove it for the 1st time since. Got about 10 miles in before it started again.
Any suggestions? And if so and you think you know, is there a dyi out there somewhere I can use as a reference?
Thanks!!
-Chris
Thanks!!
-Chris
Originally Posted by luder_5555,Mar 15 2010, 09:17 PM
how are your brakes? could be the squealer on those.
rotational noise that becomes apparent after you've driven for a bit?
sounds like a wheel bearing. you won't really be able to "check" the wheel bearing, your best bet is to make sure it's not something else (ie brakes, diff, etc) then replace the wheel bearing on that side.
some people will say to "check" the bearing by grabbing the wheel at 3 and 9 (or any other corresponding 180 degree locations) and try wiggling it to see if there's free play. if there is, you almost def have a bearing problem...but you can have a bad bearing without play also, so this method isn't foolproof.
your scenario sounds exactly like the first time my driver's rear bearing went bad. after the car was warmed up, there was a metallic rotational squeak that showed up, and became most evident when slowing to a stop. my guess is you've got a bad bearing
here's what the exploded view looks like:
Mine was the same and I had the bearings replaced in the past. Since the dealership that did it would not stand behind their work (claiming 1 year warranty) I took a close look myself.
Concluded they has not been torqued down properly (or not staked right and loosened) I pulled the axle nut, greased the back, and torqued them back down.
Quiet for now but expect this will be an issue in the future.
forgot to mention (because it's been a while) that i re-torqued my axle nut once i heard the squeal, and it went away for a little while, but came back...probably a couple months later
And thats a TON for the info!
-Chris
