Squeaky strut mounts?
Old 08-18-2006, 09:30 AM
CosmosMpower's Avatar
Default Squeaky strut mounts?
Anyone ever experience squeaky strut mounts in the rear? My 00 with 85K miles recently started squeaking very loud on every bump. I thought it was the shocks dying so I replaced the shocks/springs with some fresh takeoffs from an 02 car. Then I noticed a bushing was slightly torn so I bought a bushing and took it to a shop to get it replaced.
They called me and said that they thing it's a shock mount up top. The noise did seem to come from higher up in the trunk area. I'm wondering if it's common to have a strut mount failure at this kind of mileage. Car has been autocrossed for nearly it's entire life.
Old 08-18-2006, 11:21 AM
SpitfireS's Avatar
CosmosMpower Posted on Aug 18 2006, 07:30 PM
My 00 with 85K miles .... Car has been autocrossed for nearly it's entire life.
85000 miles of autocrossing
What do you think?
The fresh shock/spring assembly (?) came with fresh bushings and all.
That leaves upper/lower a-arm bushings.
Where did that torn bushing come from?
Old 08-18-2006, 12:24 PM
What do you think?
I wasn't thinking right and forgot the whole assembly that was probably worn out was part of the old coilover I took out.
The torn bushing is in the upper control arm, I guess I should be asking if that's a common failure point. The other 3 upper control arm bushings look fine but the one on the right side on the pass side looks bad. The mechanic took a stethescope (sp?) and said he could hear squeaking from both the pass side bushings even though only 1 looks torn.
Guess I'll have to order another one and just do that whole side. Or is it cheaper to get a whole UCA and bolt it in myself?
Old 08-19-2006, 03:52 AM
SpitfireS's Avatar
What is a "UCA"?
Don't forget to pre-load the suspension before tightning the bolts up to spec'd torque.
Old 08-19-2006, 06:59 AM
aero3685's Avatar
Originally Posted by SpitfireS,Aug 19 2006, 03:52 AM
What is a "UCA"?
upper control arm?
Old 08-19-2006, 08:48 AM
SpitfireS's Avatar
aero3685 Posted on Aug 19 2006, 04:59 PM
upper control arm?
That WMS.
(Would Make Sense)
Anyway..
Replacing the UCA involves poppin' the UABJ (Upper Arm Ball Joint).
Do you have the AT (Appropriate Tool) for that?
(it is a serious question)
Old 08-22-2006, 07:29 PM
A769's Avatar
i have the same problem but with only 27000 miles on MY01. found out exactly what it is yet?
Old 08-24-2006, 11:30 AM
That WMS.
(Would Make Sense)
Anyway..
I don't have the proper ball joint removal tool, is it a generic tool I can rent at autozone or honda specific? At this point it has to be the bushings in the upper control arm, I'll replace them when I get around to it.
We autocrossed the car last weekend and it stopped squeaking for about 3 days then came back.
Old 08-24-2006, 05:53 PM
DFWs2k's Avatar
hey Cosmos, did you take it to a shop in Denton?
Old 08-25-2006, 07:23 AM
I did but they didn't do anything. 1 shop had no idea what they were looking for and the second thought it was the bushings as a "guess". I wasn't about to pay 150 bucks to let him tear into the car and guess some more. Probably just going to buy a whole UCA with fresh bushings pre-installed and change it out.
I saw an AP1 silverstone S (with invidia exhaust and a radar detector mounted right in front of the driver) around town all day and parked in front of a house. I guess that was probably you
Quick Reply: Squeaky strut mounts?
