Squeaking noise when decelerating?!
Just two days ago I noticed my s2k has a squeaking problem which sounds like it's coming from the passenger side front. It squeaks when I am slowing down on neutral like right below 40mph and as the car slows down (with or without braking) so does the rate of the noise. It's like a mattress type of squeak. It seems like it only happens when I am on neutral or have the clutch in as I slow down because if I put it in gear the noise goes away even if im decelerating. Sounds like it's coming from the wheels but have anyone of yall gotten the same issue? thanks.
I get the same noise on my MY00. I'm going to be taking the door apart this weekend when I run new wires and speakers, so I'll let you know if I find anything that may have come loose.
The only thing that comes to mind for me are engine mounts. With car in neutral the engine is free to vibrate, under a load the driveline (torsional) resistance may reduce how "loose" the engine sits on its mounts. Granted, this is a wild guess, but I can't think of too many things that would be affected by what you have described.
I had this problem one time and i know the sound came out of my rear driver wheel....The tech though it was a brake problem...but at the end it was the wheel bearing......That was only the begining of this year, and now i have another squeaking noise coming from either the front or the rear passenger side....not sure if it is another wheel bearing issue...and i have a 2000. not sure if it is the axle....
