Spun Connecting Rod Bearings Question *UPDATE ON POST #21 W/ PICTURES*
Hi There,
I had a pretty substantial oil leak from my F20C motor that I didn't notice until the worst occurred. I am fairly positive that I have at least 1 spun rod bearing (Engine knock at 3,000 rpm and above). I am taking apart the engine (bottom of the car) so that I can see what damage there is. I have read 15-20 threads that have never given definitive answers or steps on doing all of this work so I have been reading the service manual and learning about everything myself. Perhaps, there is an expert that can answer a few questions for me.
1. If the crank is not scored and the cylinder/block walls are not scratched, will I be fine after replacing the bad rod bearing?
2. If the crank is scored and the cylinder/block walls are not scratched, will I be fine after replacing the bad rod bearing and the crank?
3. What other potential problems in the engine should I be looking for?
Pending on my findings I plan to replace the bad bearing (probably all the rod bearings actually) and if crank/walls are fine then I will put everything back together and do a compression test. If I get solid numbers on all cylinders then I think that I will be fine. I fully realize that there is a possibility of the main bearings, etc. of being faulty as well which is why I will check the oil pan contents 1 week after driving the vehicle.
Furthermore, I did not find any step by step process of doing all of this or any threads with a well thought-out explanation on how to assist with this problem. I know that many people just buy another engine and swap it, but I think that is a bit excessive. I find it therapeutic taking apart the engine anyway.
If I were to purchase a new F20C is there a specific vendor that has good prices? Thanks a lot for your advice and help. If there is anything you want to point out that I am not aware of then please do so.
P.S.
I found a significant amount of metal shavings in the oil pan which are likely one of the bearings.
P.P.S.
The engine has 68,000 miles on it.
P.S.
P.P.S.
Well, I am not too worried about having the car in the garage for a few months. Track season starts in May for me so I just need the engine running by then. On the bright side of things, I am glad that after all of this I will be much more knowledgeable about the F20C and very vigilant in the future when it comes to my engine. I wonder what it would take to design a better sensor to keep real-time data on the oil levels of the vehicle? (I do some embedded systems work)
On a tangent, I plan to do a full write-up with pictures (documenting everything) on checking the bearings etc.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
In general... Spun rod bearings mean:
Crank = Throw away
Rod with spun bearing = Throw away.
Either replace the crank and that rod(s) and balance, or just replace the shortblock.
Crank = Throw away
I figure that it will be around $1000-$1500 vs. $2500 - $4000 for a new block.
Also, I am going to take calipers to the crank this weekend and also check to see if it is marred/burned etc.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Crank = Throw away
Crank = Throw away
Originally Posted by apme123' timestamp='1359063718' post='22290310
Learn to check your oil, I am sure after an expensive lesson like this you will be checking it every fill up. "BOTH SIDES OF THE DIPSTICK"
