Spoon Titanium Shift Knob
now i know these spoon shift knobs are light... but do they counter sink??
i'm debating between ARC and Spoon shift knobs..
man, i just put mine on yesterday. it is much lower than stock. countersunk or not, it sits low enough now that i don't need to raise my hand much to grab the shifter, i can just rest it on the center console and just barely reach up to grab the spoon shifter. the throws are much shorter now too, took me all day today to get used to it.
Originally Posted by LemonS2k' date='Feb 14 2005, 12:20 AM
now i know these spoon shift knobs are light......................
well, it is pretty weightless, not much more than a couple of coins. however, when i held it when i first took it out of the box i was actually pretty iffy about its weight, i wasn't sure if it would provide a solid throw. once i put it on, it was definitely different, but once i got used to it, it became a very natural feel and motion, then after that, you just don't think about it anymore.
Titanium is denser than aluminum, but it is also much stronger, so you need less thickness of it to maintain comparable strength to aluminum. As a result, the products made from Ti are lighter.
Anyways, back to the knob.
Dave, the Spoon knob is hollow inside. Think of a titanium egg shell and you have the idea.
And it is truly brilliant. Without a big, heavy stock Al or Ti knob on the end of the stick to dampen vibrations and motions, you feel EXACTLY what the gearbox is doing. It's absolutely the best thing. I love mine.
This is the first version of the Spoon Ti knob, I have the second version now and it is only a tad heavier.
It definitely sits lower than stock - it might be a tad higher than my old Voodoo knob.
......these pictures are over a year old now.
Personally, I opted for the solid Ti Voodoo knob for the express purpose of having a heavier weight on the end of the stick to dampen the extra vibrations coming through due to the presence of the blower. I found the vibration to be quite disconcerting.
solid Ti oem goodness modified by me! if any of you would like I could do this for you also for about $80
I have heard the spoon knobs break.
defeo@charter.net
defeo@charter.net
