spongy brakes until third pump problem.
so i bought some ss brake lines and installed them last week and never had to bleed the brakes myself until then. ive tried the two person method, gravity, and with a mighty vac bleeder but still spongy brakes almost to the floor while driving until about the third pump. anybody else had this same problem before? i dont see any air comin out anymore when i bleed.
yup tried that order also. fluid was comin out full stream with no air too with my friend on the brakes. hoping its nor the master since this only started when i replaced the lines.. do i just need to keep bleeding? im wasting so much fluid!
I hope your master isn't leaking into the booster, this is rare with these cars but can cause those symptoms.
What happens if you pump the brakes, then keep pressure on the pedal? Does the pedal start to go down to the floor? If so... maybe a leaky seal in the master.
