Splitting bellhousing from gearbox
Hi I need to split the bellhousing from the rest of the gearbox. I have removed all the bolts on the outside that hold it together and also 3 small ones from inside the clutch housing.
I have approx 1cm of movement when splitting but then it feels like its hitting something which is stopping it from completely separating, any help would be great
thanks
thanks
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Did you pull the gigantic Allen head plug? There's a clip behind it you need to pull, and probably a couple of other things I'm forgetting.. The Helms is your friend.
Thanks for the replies. I have got the engine and gearbox seperated already. I was hoping to seperate the bellhousing from the rest of the gearbox
Eldest Son of S2K owner!
04-08-2017 11:42 AM
s2000powered
07-06-2013 08:16 AM
