Speedo wrong?
Speedo wrong?
I just put an ap2 tranny in my ap1! Is the speedo off? If so is it by much or a little? Do i need to get a yellow box to fix it?
Thanks
Fadi
Thanks
Fadi
But is the sensor that picks up the signal in the AP2 tranny the same as in the AP1 tranny? Since our speedo is electronic, I would think the sensors would have to read the same.
As found in this thread:
https://www.s2ki.com/forums/index.php?showt...0&#entry6930319
" Keep in mind, the vehicle speed is read from the countershaft, not the mainshaft.
You will need a yellow box to re-calibrate your speedo, or just leave it as is. It will read a few MPH higher than your actual road speed, and you'll get less speeding tickets"
When Billman speaks, we need to listen.
NikosX
08-12-2009 10:44 AM
