speed limiter @180kmph
Old 09-05-2005, 09:53 AM
jmz187's Avatar
Post speed limiter @180kmph
does anyone know how to disable it? cut a wire or something. pls help. do i have to buy a greddy speed cut limiter or a hks speed limiter defencer to get rid of it. help me out. tnx
Old 09-05-2005, 10:13 AM
xviper's Avatar
I don't think mine has a speed limiter. They do in the Philipines?
Old 09-05-2005, 12:55 PM
CaptainMike's Avatar
no speed limiter here, both of mine- top speed was/is drag limited for sure.
Old 09-05-2005, 01:28 PM
Wisconsin S2k's Avatar
JDM and a couple other countries have a speed limiter at about 150mph.
but 180kph. i dont think a limiter would be set that low???
Old 09-05-2005, 02:11 PM
koala's Avatar
JDM cars are limited to 180 kph from the factory. (S2000 included).
Post in the UK forum. They import a lot of JDM S2000's and know how to disable the speed limiter.
Old 09-05-2005, 02:50 PM
xviper's Avatar
Geez, that's only 111 mph.
Old 09-05-2005, 03:58 PM
NorthCyprus's Avatar
All JDM Cars have the speed limiter. Mine aswell. I didnt remove it.
Best way to remove it is to use Apexi RSM but that wont be enough aswell, it's weird that in some cars like Integra Type-R you can remove it with this small specific Greddy part they use only for removing the speed limit, in S2k the solution is the Apexi RSM but even sometimes that wont do the job aswell, what the mech told me is that there is this adjustment they have to do with the RSM before they install it, than it perfectly removes the limit.
It's not an easy job like cutting a wire or making some simple adjustment, i experienced; even the e-manage wont remove the speed limit. We tried when i had one and (in order to adjust the 550cc injectors i installed to try to solve my problem i have with the car) my speed limit wasnt removed.
Old 09-05-2005, 04:07 PM
xviper's Avatar
Is this speed limiter a fuel cut off or an ignition cut off? Just curious.
Old 09-05-2005, 04:09 PM
koala's Avatar
Fuel cut-- it's like hitting redline
Old 09-05-2005, 04:22 PM
Billman250's Avatar
Received 1,398 Likes on 837 Posts
Maybe a US model ecu?
Quick Reply: speed limiter @180kmph
