Spark plugs too tight
Old 07-09-2014, 04:04 PM
bgoetz's Avatar
Default Spark plugs too tight
I had to change my plugs today and made two mistakes that makes me wonder if I will ever get them back out. One the engine was still pretty warm, two for some reason I was thinking 24lbs instead of 22lbs. It felt like I turned them under mild resistance ALOT. I know it is only two lbs, but that combined with a hot head is making me wonder if they are coming out when I need to get them back out! I guess should I just be thankful I didn't strip the head by being stupid and dealing with the possible consequences later OR should I loosen and then re torque them when the engine cools?
Old 07-09-2014, 04:10 PM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
You are fine.
Old 07-09-2014, 04:15 PM
tbpom1003's Avatar
Originally Posted by Billman250
You are fine.
i torque them to 35. I heard a member here almost damaged his engine due to loosen spark plug
Old 07-09-2014, 04:56 PM
bgoetz's Avatar
That is all I needed is Billman to say I am fine
Old 07-09-2014, 06:18 PM
2001-S2k's Avatar
Wait what??? 35Lbs for the spark plugs! I hope you were only kidding. I thought it was 18lbs. I know if you over torque them, you can destroy the engine, foul plugs, make piston to spark plug contact O_O
Old 07-09-2014, 06:44 PM
DrakeValle's Avatar
Yeah service manual for 2003 states 18ft lbs. I bumped mine to 20lbs and called it good. 35lbs sounds a bit excessive.
Old 07-10-2014, 03:54 AM
redlineracing's Avatar
IMO....Billman250 is the resident expert on these cars.Take his advice.
\rlr
carolina
Old 07-10-2014, 04:15 AM
Billman250's Avatar
35 ft-lbs will distort the threads in the cylinder head. Very bad idea.
22-24 ft lbs is the way to go I assure you.
Old 07-10-2014, 01:19 PM
Arcoril's Avatar
Are there any issues with removing and reinstalling NGK plugs multiple times? I know that they have a coating on the threads that takes the place of using anti-seize, but does that get worn away and increase the possibility of the plug getting stuck?
Old 07-10-2014, 05:14 PM
Utah S2K's Avatar
NGK plugs are supplied with a Trivalent Zinc coating (silver or gold). The coating is lost upon first installation. If you reuse a plug it should be lubricated.
Utah
P.S. You can get this information from NGK technical support directly. Just contact them on their website.
Quick Reply: Spark plugs too tight
