Spark Plug Recall?
Old 08-01-2003, 12:20 PM
wantone's Avatar
Default Spark Plug Recall?
So I'm bringing my car into my mechanic to change some spark plugs. Reason? I hear changing them before a dyno session would help improve figures. Anyhow, my mechanic calls Honda to order the plugs and the guy says there's a recall on the plugs and to bring the car in. I rush back to the office and do a search. Indeed there was a recall but for cars pre-2002! Am I reading the threads correctly? Was there a recall for 2002? Have you guys changed your plugs yet
Old 08-01-2003, 12:44 PM
dreamgetter1's Avatar
mine were changed on the recall prior to me buying the vehicle.
Old 08-01-2003, 12:50 PM
matrix's Avatar
Depends on when your '02 was built. My '02 had this tsb done.
Search the Toronto forum and you will find a thread I posted with pics when I had mine done...
Old 08-01-2003, 01:07 PM
Former Sponsor
Gernby's Avatar
This definitely was a recall. I received a letter in the mail about my '02. The replacement plugs have a different gasket ring thingy, and they are supposed to be torqued to a higher spec (I think 18 ft-lbs).
Old 08-01-2003, 01:31 PM
prideauxx's Avatar
Just had this recall performed on my 2000 S2000; got a copy of the TSB (#02-042) here's the spill:
Dated July 10, 2002
"Background
Faulty spark plug gaskets can cause the spark plugs to loosen. A loose spark plug can cause the engine to misfire and the MIL to come on"
gernby's correct--they are torqued to 25 Nm (18 lb-ft)
Old 08-01-2003, 01:35 PM
wantone's Avatar
Thank you guys but what if my recall letter never arrived
Old 08-01-2003, 06:46 PM
JS2KRN's Avatar
Mine was changed a month ago. I have a 2001 w/ 30K miles.
Old 08-01-2003, 08:23 PM
xviper's Avatar
Have your dealer cross reference your VIN. If it is entitled and has not been done, they'll do it.
Old 08-01-2003, 08:31 PM
S2K Mayhem's Avatar
Wantone,
Call a dealer, and ask them to do a Vehicle Status Inquiry on Interactive Network. All you need to provide is your VIN. They'll be able to tell you if there are any open campaigns on your S. Or, PM me your VIN, and I'll run it for you on Monday, and let you know.
Old 08-02-2003, 10:50 AM
wantone's Avatar
Thanks S2K Mayhem and Xviper! I'll call Monday...
Quick Reply: Spark Plug Recall?
