spark plug hole is stripped
hey i have a 2000 s with 37k on it just wanted to know if any one has ever had this issue a stripped spark plug hole. i had a problem with this like four months a go.now it is totally stripped some pepole have said helicoil and others say not to what do i do. i want to go supercharged someday so will this helicoil work with boost. or just go and get a new head o ya and by the way i am having all the work done at the local honda dealer.
thank
thank
I blew a sparkplug out of the head, taking some threads with it.
Helicoiled as a temp fix.
You DON'T want to do this. The plug won't seat perfectly and will be at a different height in the combustion chamber. Plus, if you're SC, you'll have to replace plugs more frequently anyway. The helicoil won't hold up.
Save yourself the headache and buy a used head for under $500.
Have the dealership upgrade the retainers to AP2 (if an AP1 head).
option A is a used head.
Instead of a cheap helicoil u can fix it witha durable TIMESERT
there's a special package for sparkplug holes
www.timesert.com
www.timesert.com
I would think a timesert would be better for an iron head. Expansion of aluminum might be tricky.
Having a machine shop rework the head might be cheaper by a few hundred, but I think the peace-of-mind of a new (used) head would be worth it.
I have done this twice on 2 S2000 heads. One engine is N/A tuned and used for racetracks - no problems!
Please don't use Helicoil!! Timesert is completly different and much more reliable.
