spark plug gaps
Most plugs come with a pre-gapped setting, but I would still recommend that you at least check the gap to ensure it is within the spec you are looking for. Most times in my experience I have had to regap the "pregapped" plugs to fit the proper spec for our car.
i went to autozone and they checked the gap, they said it was fine. But i removed one plug and when i eyeball it the gap on the old plug is slightly larger. The new plug looks bent in a bit more. is this normal?
I also ran into another issue. When i try to remove the plug the extension comes off and i cant get the plug and the plug socket out.I was able to once but it was a bitch. Gonna try some ducked tape on the extension and socket to make them stay together and yes, ill be careful..
I always check spark plug gaps.....just to make sure.I run NGK copper plugs in my 03S @.044
A magnetic pick-up tool is your friend in hard-to-reach spots.
\rlr
carolina
\rlr
carolina
OK..replaced the plugs and all is great. car started up fine and a test drive showed me a bit more pep especially under VTEC. here is the pic of the old plugs. i assume these were from the factory as the car has 62K on it. Boy, they were a bitch to get out.
Yeah they looked pretty good when i took them out and figured for 10 years old they held up well. But i got a power kick by replacing them and i noticed the car reved higher quicker. Even the VTEC sounded smoother so im happy.
Paperboy7777
01-09-2012 09:23 AM
