Spark plug electrode - BROKE OFF in #1
Those numbers are not good.
I'd say if you're lucky, you've got some mechanical valve seat damage.
That doesn't explain the readings in cyl 2 though....LEAN is coming to mind here.
No luck on the tape-thing, nor can I "feel" that there is anything in there.
I don't have a laptop yet. If I uploaded from my AEM to a desktop taken into the garage, would I be able to pull up recent datalogging or is that something that has to be setup first?
Also, didn't know if you saw a possible explanation to my potentially lean situation.
The plugs also got lighter as they progressed to the #4 plug. I'm thinking this was in compensation for the #1 not being able to burn all its fuel. The wideband read a certain condition(rich) and the EMS adjusted accordingly. I run in closed loop when under normal(low-load) conditions.
I'm thinking the hanging would create less of a mess.
That just looks like detonation to me.. that fragment of plug was probably reduced to slag and exited the exhaust. Seen it before on other cars often accompanied by other damage. When you get it running again you need to look at your state of tune.
PM fperra, or maybe he might chime in.
I read his post a while back when the spark plug porcelain part broke off into his engine (I think it was all 4).
Or if the search works check it out.
May be some hope for you.
My guess is that at some point, someone dropped the plug, or improperly gapped it, damaging or weakening the electrode.
This is a rare occurrence, even for a SC'd car. I heard some N-D Iridiums had this happen pretty early on, but at the center electrode, not the - .
Well, after not being able to find the missing piece and reading some more comments here, I elected to install new plugs and see what I had.
Car feels wrong and sounds abnormal. I pulled her back in the garage. Man, I wish I had a laptop.
I had the same thing happen with my 944. After having routine service done (tuneup) I checked my plugs about 5 weeks later during service I would do at home. Turns out the plug the garage used had broke off in the cylinder and I went off the chain. Try as I may I never found any parts (of course not DOH!) but the top end went south on that motor about 6 months later. I won't use those types of plugs anymore in my cars.
Spend a weekend in your garage and pull the head. Or have someone do it for you. Before you do that though, order a new head gasket, exhaust manifold gasket and intake manifold gasket. Until you pull the head you are not going to know what you have wrong. After all the porcelain disappeared from four Denso iridium plugs on mine, I had no choice but to pull the head and face the music. Fortunately, in my case, no damage. I guess the porcelain just turned to dust. Probably what I get for cleaning them by sand blasting.
