Spal fan install help
#21
You have it wired wrong. Since you're using the SPAL interconnect, you need a second relay to switch in the ground for it to work.
85 on relay goes to Blue/Black
87 to chassis
86 to chassis
30 to gray wire
87a no connection
87 to chassis
86 to chassis
30 to gray wire
87a no connection
#24
Originally Posted by 99SH
You have it wired wrong. Since you're using the SPAL interconnect, you need a second relay to switch in the ground for it to work. 85 on relay goes to Blue/Black 87 to chassis 86 to chassis 30 to gray wire 87a no connection
#25
Take a look here for the complete wiring: https://webstore.spalusa.com/content...O-KIT_SPEC.pdf
Page 4 has the details for the 2nd relay.
#26
Here's what I was thinking using the hardware you have now. In this configuration you don't need the 2nd relay. This setup will work given the relay coil does not have a diode across it. I emailed SPAL to confirm and will post here when I get a reply. You can try in advance if you wish:
#27
The picture says to ground it .. Correct ?
Why does my chart say switched ignition ?
#28
Correct, ground the orange. Using my method you won't need a 2nd relay.
The SPAL wiring has you connecting the Orange to +12V switched and the Gray wire to the second relay. The purpose of the 2nd relay is to apply GND to the Gray wire when the OEM Blue/Black wire gets +12V (i.e. when the fan is triggered to turn on).
Either method should work. Again, I just emailed SPAL to confirm my approach is OK - specifically that there is no diode across the relay.
Hope this makes sense.
#30
These diagrams make a lot more sense !
I will try to ground the orange wire tomorrow and see what happens .. Worst comes to worst it won't blow anything right ? I hope I don't have to get another relay
