Spal fan install help
[attachment=90075::] This is the harness assembled
[attachment=90076::]
This is the orange and grey wires .. Orange will go to my radio fuse and the get will splice to the blue and black wire on oem harness for the oem fan ..
Considering I don't know too much about wiring .. I'm just gunna run it the way the harness is assembled .. And shorten it because there so much xtra wire .. And I don't even see where I can stuff these relays I have no room under the hood as it is ..
[attachment=90082::]
[attachment=90085::]
I broke a bolt in the top fan mount on the radiator so have to extraxt that tomorrow but the fans is in and fits nice .. Can't fit a extreme on the driver side due to intercooler piping ... I tried to get the fan far low to the bottom lip of the radiator which is closer to oil cooler .. Tomorrow I will finish the wiring .. Orange wire will go to radio fuse and grey wire will get spliced with a clip to the blue and Black wire on oem harness
Ok wired up the fan and it don't kick on ... I ran the orange ignition wire to the abs fuse ... And connected the grey temp wore to the blue and black wire on oem harness .. Do I have to ground the black wire on the harness too? Everything else seems to be in order ..
[attachment=90176::]
Tried to turn ac on and the Rpms drop and no fan
