spacer and wheel studs
AJ Racing told me the Endless 6 pot (which is a bit bigger than the Stoptech caliper) would fit a low +40 offset (17 inch) wheel with a 5 mm spacer. I am assuming a 5mm spacer should work fine. Dont know anyone with that setup. I can tell you I am running Endless 6's with a +45 front at 17x7.5 with a 5 mm spacer and it works fine. I am switching to the new SSR wheel (forged) thats not out yet and all I can tell you is its a +50 front and you need no spacer..
