Sound System Intermittent Problems
I have an Alpine deck with the alpine rpf300 amp connected to a fosgate p2d10 sub. The system goes in and out randomly - usually over a bump/surface change. The deck always stays on, the but the amp turns off. Do you guys think it's most likely an issue with the remote wire behind the deck/ground wire? I checked the ground already, but it happens still. My next step is the remote wire but I just wanted some insight.
Thanks guys!
Thanks guys!
You will probably get a better answer here https://www.s2ki.com/s2000/forum/26-s2000-electronics/
Unless u have speakers and amps under your hood
