Something wrong with OEM radio
Old 11-05-2009, 05:39 PM
IIXtremeHansen's Avatar
Default Something wrong with OEM radio
Okay once in a while i start the car and the radio dosnt power on immideately. It takes a while before it powers on. I press the on button and it wont turn on until a few minutes later. Is something not powering it?
Old 11-05-2009, 07:14 PM
s2k aok's Avatar
mine's an ap1 and no problems, i'd assume yours would work better, being newer and all...
Old 11-06-2009, 08:56 AM
Vinsfeld's Avatar
never had problem with mine
Old 11-06-2009, 09:46 AM
croftoncustoms's Avatar
havn't had that problem yet but i have had to replace mine already (05) because the thing somehow overheated and destroyed the cd player. done that to two OEM radios already. see if your connections are plugged in all the way. it is a tight fit when installing the radio.
Old 11-06-2009, 10:04 AM
Banned
HondaRehab's Avatar
i have an 05 and an 00 and neither have radio issues
Old 11-06-2009, 10:14 AM
spectacle's Avatar
Sounds like you've got a partially blown fuse
Old 11-07-2009, 05:21 AM
hondaphreak's Avatar
let us know if its the fuse. thats something ive never experienced or heard of but sounds possible in theory.
Old 11-08-2009, 01:04 AM
will check and let yall know, thanks
Old 11-08-2009, 01:35 AM
DFWs2k's Avatar
this has been brought up multiple times, it's a relay malfunction, AFAIK
Old 11-26-2009, 09:25 PM
kind of late but for peeps that may come across this problem. I pop the hood, open the fuse box and pulled out the acc/backup fuse and turned it around and put it back in. Start the car and green light comes on instantly. wierd but works now.
Quick Reply: Something wrong with OEM radio
