Something wrong with Cylinder #4?
Hey guys, so I recently replace my engine with a 2000 model and it has about 70k kms on it. I wasn't aware that the earlier 2000 models had issues with oil and many replaced their oil jet bolts.
It wasn't until I got the engine in and started it up that I noticed louder than usual valves. My previous engine wasn't nearly as loud. So I was thinking maybe it just needs a valve adjustment.
However after a bit of researching on the forums and hearing about the valve noise that could be a possible sign of cylinder #4 going bad due to oil starvation, I recall seeing a bit of build up on the exhaust cam lobe on #4.
Now this has gotten me worried so can anyone give me some input on the possibilities of #4 going bad? Also how much does a set of oil jet bolts cost? Thanks.
**Edit: I added the video just to give people a bit more detail into the noise i'm talking about. Also i'm assuming the whistling/whining sound is from the air pump on start up?
Valve noise
warm engine valve noise
Valve noise
I think hardtopguy has the upgraded oil jet bolts you need. Did you replace your block and head with the MY00? or did you just replace the shortblock? Just asking b/c if you had just the shortblock you should have inspected the cylinder walls before installing the head and putting it together. Im pretty sure your suppost to adjust the valves also after putting your motor back together, thats what I did. Mine had a scorred cylinder also. A video would help alot, its hard to diagnose a noise that you cannot hear on the internet. I say do a valve adjustment first, and see if that helps any with the noise at all.
thanks for the quick response, I replaced the whole engine, head/block. The engine wasn't opened up so I couldn't really see. I'm planning to do a valve adjustment but my mechanic says let it run for a bit first before doing the adjustment. I will also try and get a video to give you guys a better understanding when I say my valves are a bit loud. Thanks.
Ohh okay. Yeah I would get a valve adjustment done asap though, before anything worse happens. Its a used engine, so it doenst technically need broken in. Yeah just try to get a video of it also to help diagnose. Also, you could always get a borescope. Take out your spark plugs and you can take a look in your cylinders with it. They make fancy ones with a decent size screen and a light on the end of it so you can see everything in your cylinder very clearly.
