Something seems to be missing! Empty threaded hole in engine.
Hey guys,
I was getting ready to install my billman's tct when I noticed an empty threaded hole next to the TCT. What is this?
Untitled by stoiclawyer, on Flickr
Thank you sir! Apparently this is a common panic when fiddling with the tct. Other folks have said it is for an engine hoist mounting point, etc. Thanks! I was cussing!
That bolt hole is there for you to put a bolt in and it's used for engine removal. Since you're not removing the engine that hole is useless to you.
as mentioned it's an exta hole for hoisting the engine. Many people use it for engine torque damper mounting since it doesn't get used.
rudeS2k
12-30-2005 07:19 AM
