Soft top loose, Vibration under accell??
Hello there,
i need some help !
1- Can the roof be tightened (my99) ? it seems to be getting a bit slack at the back and flaps around on the motorway, very annoying !
2- Shudder under hard Acceleration, gets progressively worse as you go through the gears. ie fourth gear through 100mph. could this be my old noisy buzzy clutch giving way ? or could this be a bad diff / prop shaft / driveshaft ??
please advise...
thanks in advance
edited as i cant spell buzzy !!
i need some help !
please advise...
thanks in advance
hey steve hows melbourne? i used to livein vero beach !
yeh i know about the striker plates TSB ...that just pulls the leading edge of the roof down further and hence tighter...
the roof is slac at the back...around the rear screen... i have tried pushing the rearmost roof beam backwards/downwards. but it looks like it is still slack ??
cheers
raz
btw - definetely think i have that inner CV joint problem...was there ever a complete fix from honda over this?
cheers
raz
but the shudder during acceleration sounds like the famous pitting of the cv joints.
John
interesting point/.//
i wonder how much they will charge here in england..as upholstry shops aren t ten to the dozen as they are in america...
plus it already has two small tears in the roof... i dont know if its worth it..may just save for a retro fitted later spec mohair roof..hmm
