Are soft-top latches adjustable? How?
Hello all,
My soft top is making a ticking noise and I also suspect it for a very loud aerodynamic noise coming up at 100mph. I would like to make sure the soft-top is tightly secured and I was wondering if the latches can be adjusted, and if so, how?
Thanks,
Michael
Thanks,
Michael
Hi Michael, mine did the same for ages and it was well annoying, I took the latches off and wedged some insulation tape in the gaps- 'problem solved' & as for the wind noise all you do is when you've put your hood up and lock'd it just tap the roof switch back a little until the roof is pulled taut.
Job done
Andy
Job done
Andy
