Soft top isn't working
Yesterday out of the blue my soft top wouldn't go up, so i just had to pull up on it and latch it up. the problem is that it wont go up or down. the fuse under the hood is fine, so i don't know what could make it stop working...? any help would be great! thanks. oh yeah it a year 2000
could be the motor for the top is burned out. Not likely, but possible.
There aren't that many fuses, just check them all . Besides, its good to know if any are burned out.
Does the top switch operate the windows or does it do nothing when switched? Couldn't hurt to check all the fuses just to be sure (as xviper said, there are multiple fuses to check for this).
An after-thought:
Have you been doing anything under the center console of late? There have been instances where the person did not "click in" the top switch or somehow tampered with the ebrake interupt switch.
naw i did the brakes, and i took off my right hand door panel to find out that my window regulator is bad, but i don't think that would affect it would it??
