so my s2k is always locking the brakes
ive got the ABS light on and off all the time, but when i have to brake hard it locks up the brakes, there are no dtc's for it.. it has new brake oil.. so what could it be? maybe the abs pump?
Originally Posted by Slows2k,Feb 16 2010, 09:50 PM
What have you done recently to the car?
Originally Posted by alpha318,Feb 16 2010, 10:02 PM
what pads? what rotors? what tires? is the ABS light on only when braking?
brake booster or master cylinder could be bad.
Originally Posted by SpitfireS,Feb 17 2010, 10:24 AM
axs2000 Posted on Feb 17 2010, 06:27 AM
Does this mean you have tried to read the code with a OBDII?
When the ABS light is on = no ABS.
Whenever I drive fast (above 220km/h.. NO!, that doesn't happen very often) I get the ABS light and only when I drive that fast.
Most likely one of the rear wheel sensors.
Right now I can't be bothered to find the problem.
Driving normal = no ABS light = ABS works.
Under what circumstance comes your ABS light on?
Is it on all the time?
Is it off after the self diagnostic time when you start the engine after a "key-out-of-ignition"?
