So my car has been sitting for 1 1/2 years..
My car has been sitting in the garage for 2 years (I came back to the states a few months ago to start her up).. I've been out of the country for a very long time due to personal reasons and had no other choice but to leave her behind sitting in the garage. I know it was bad so help me get her fixed up again.
What is the first thing I should do to it.
She needs a new battery for starters..
Any maintanance suggestions?
+ Cost?
Thanks.
+ Cost?
Thanks.
fuel is probably shit so don't drive it hard until it gets changed. maybe a bottle of injector cleaner if you want while your filling up.
tire pressure
oil change, and maybe tranny and diff fluid if you'd like
and.........................a WASH!!!!!!!!!!!!!!!!!
tire pressure
Air in tires, maybe replace if flat spotted from sitting to long
New oil, tranny, diff fluid
New plugs
New gas if you didn't add anything to keep it from going bad
Maybe grease the seals on the top to keep them good
New plugs
I was away from my car for a little over 2 years as well. Here is what I did when I got back.
1) Oil Change (Royal Purple, Mobil 1, Whatever you feel like really)
2) Transmission fluid change (I would suggest Amsoil MTF or Redline MTL)
3) Diff Fluid Change (I would suggest Amsoil Severe Gear 75w110)
4) Check Belts and Hoses under the hood
5) Apply Shin-Etsu grease to seals
6) Put a bottle of fuel system cleaner in the gas tank and top off if not full (I suggest Redline Fuel system Cleaner)
7) Wash and wax
8) Dust / Clean interior
9) Drive it easy for a couple gas tanks
That's what I did. Good luck man, and enjoy your S2000 again.
-Ian
7) Wash and wax
-Ian
7) Wash and wax
-Ian
7) Wash and wax
-Ian
But I'd like to buy the stuff and take to my usual mechanic since I know he doesn't have most of the stuff..
How many bottles of each thing would I need for all the fluids? Thanks
5.1 quarts of motor oil (5-6 bottles)
1.7 quarts of transmission fluid (2 bottles)
1 quart of diff fluid (1 bottle)
1 bottle of fuel system cleaner (1 bottle)
good luck and enjoy it.
-Ian
-Ian
Brake fluid should be changed every two years.
https://www.s2ki.com/home/2011/01/24...ecked-yours-2/
ah, true true, i forgot to mention that one. I went ahead and changed the brake fluid and clutch fluid at the same time. I use ATE Super Blue for both. Thanks for the reminder dwight.
-Ian
-Ian
