So I changed the Drive Belt today @105k miles
Old 07-31-2007, 05:14 PM
Slows2k's Avatar
The only Honda's in the current model line up that don't use a Timing chain are V6 powered. Every K series engine in Accords, RSX, TSX, CRV, Element and RDX all use a chain. So do Civic Hybrids and Insights.
Old 07-31-2007, 05:20 PM
Mystiqueskillz's Avatar
What are the advantages over one another between the timing chain and timing belt?
Old 07-31-2007, 05:33 PM
iam7head's Avatar
belt snaps, chain don't
Old 07-31-2007, 05:35 PM
Slows2k's Avatar
Chains can break. They just last longer than a belt.
Old 08-01-2007, 05:30 AM
JonBoy's Avatar
I didn't know all of the 4-cylinders use a timing chain. Thanks!
Old 08-01-2007, 05:31 AM
JonBoy's Avatar
Timing chains are also generally louder than timing belts, which is (I believe) one of the main reasons they were not used for a while. Chains are also more expensive to buy.
Old 08-01-2007, 08:05 AM
kenstyle's Avatar
[QUOTE=iam7head,Jul 31 2007, 12:49 PM] The funny thing is i changed my sister's 2000 celica GTS' drive belt couple days earlier. It took me a good 4 hours to get the job done with a help of friend.
this is what we took off in order to get the belt. it cost more than my belt for some reason, it was around 36+tax
2 piece motor mount(6 bolts total)
bracket for the AC and PSlines(since it's all in the way)
autotensioner
engine bay cover
lower engine bay cover
there's about 2 inches of working room there, 2 a/c line was in the middle, the powersteering line was there, the cruise control line is there. The autotension will not go back in without a 5 foot cheater bar on the pivot point and a pry bar. oh, did i mention there's about 2 inches of room to do all the work in? it's worse than the VW aeg timing belt job that require lowering the motor
thanks yamaha/toyota
Old 08-01-2007, 01:04 PM
03 9g's Avatar
when does a timing "chain" need to be replaced ?
Old 08-01-2007, 02:22 PM
RACER's Avatar
Just a rough guestimate, the timing chain in the S2k should last a minumum of 150 - 180k miles.
RACER's Avatar
If it stretches.
Quick Reply: So I changed the Drive Belt today @105k miles
