So Honda NOW makes a gear oil
Old 12-24-2013, 03:00 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Originally Posted by 2003AP1
Originally Posted by JFUSION' timestamp='1387912001' post='22936937
[quote name='2003AP1' timestamp='1387900417' post='22936721']
I also use the Amsoil severe gear as well. But I was just seeing if it was another option to consider.
The most popular options in no particular order are: Honda 80w90 , Mobil1 75w90, Redline 75w90, Amsoil 75w90 , Amsoil 75w110, Amsoil 75w140, LE1605 (SAE110). Redline, Amsoil, and Castrol also make versions of 80w90 gear oils. I would put all of these fluids above the fluid that you listed in the OP.
Is the Honda 80w90 from the motorcycles or something? I never seen it at the dealer.
Is it GL5 as well?
[/quote]
They brought it in from one of their other divisions, I can't remember if it was the motorcycle division or the marine division, but our local dealers have been carrying it for a long time.
Ever since dealers started blowing up S2000 diffs with improper Honda fluids designed for the CR-V they brought in the 80w90, it is in a Honda bottle. I think it is the one found on this web page
http://motorcycle.honda.ca/parts-ser...oil-lubricants
Old 12-24-2013, 03:31 PM
flanders's Avatar
This is what Honda in Europe recommends, not sure if it's the same stuff you call 80w90?
It's stupid expensive, I paid $65 for one 1l bottle from my local dealer.
Old 12-24-2013, 03:39 PM
zeroptzero's Avatar
Good lord that is expensive, you should be able to find Motul in Europe for less money ?
Old 12-25-2013, 03:01 AM
flanders's Avatar
I bought a bunch of other stuff at the same time so didn't realize until I got home how expensive that bottle was.
Never going to pay that again.
Funny thing was I tried discussing other diff fluids with the manager there and got told nothing else would work and just an idiot would try anything else
Old 12-27-2013, 11:33 AM
postman's Avatar
the fluid you put the link to is transfer case fluid for honda 4 wheel drive systems.
Old 12-27-2013, 12:14 PM
08S2000's Avatar
Edited because didn't read the whole thread carefully.
So this is not the same fluid that destroyed differentials on the S?
Old 12-27-2013, 02:01 PM
2003AP1's Avatar
I know what it is meant for just wanted to know if it transfered over, its still GL-5 gear oil. But I guess its a bit too thin.
Old 12-27-2013, 02:02 PM
2003AP1's Avatar
No, this is actually gear oil..
Old 12-27-2013, 02:03 PM
2003AP1's Avatar
So if it was 75w-90 it would be ok I guess?
Old 12-27-2013, 02:04 PM
2003AP1's Avatar
Honda makes an 80w90 diff fluid, and most dealers should carry it. If you are going to use a dealer fluid I would use that before the one that you listed.
Personally I would avoid the fluid that you referred to. The term lower viscosity scares me, it is going to be thinner than a 75w90 which is the thinnest fluid I would ever put in the diff.
Based on all of the fluids I've run, the lowest wear has come from the thickest fluids. I've used 75w90, 75w110, 75w140, and SAE110. I believe that our diffs get better protection from a thicker fluid, based on the operating temperatures which it is going to be used.
Quick Reply: So Honda NOW makes a gear oil
