snapped bolt on ignition coil
Old 08-28-2012, 11:13 PM
kap
kap's Avatar
Default snapped bolt on ignition coil
do what?
Old 08-29-2012, 03:37 AM
zeroptzero's Avatar
Received 3,770 Likes on 2,660 Posts
The bottom part of the bolt should come out easily once the top is broken off, get a bolt extractor kit if you can't get it out by hand or with a small drill bit in reverse. Looks like you have a little nub sticking up, try to get a pair of piers on it to spin it out. If not then extract it. Then just buy a new bolt - 6mm x 1mm , not sure of the length, but you can measure the two pieces.
I doubt the threads are damaged so you should find the threads to be okay if you can extract the old bolt.
Old 09-02-2012, 07:02 PM
eastcoastbumps's Avatar
Alternatively, you can dremel a notch in the remainder of the bolt and use a flat head screwdriver to get it out.
Old 09-03-2012, 08:46 AM
RacerXI's Avatar
What those guys said. Be sure to cover your spark plug hole before you start working. I also drill a hole into the corner of the bolt and use a punch to turn it. Good luck.
Old 09-03-2012, 10:52 AM
RedY2KS2k's Avatar
I agree with eastcoastbumps: that picture looks like you could cut a slot in the stub that's sticking up and use a flat-blade screwdriver. A Dremel with small cutoff wheel is the tool of choice; a hacksaw might work in a pinch.
A left-hand drill bit and a reversible drill is another possibility. The bolt should spin out as soon as the drill bit starts to bite into it. You shouldn't need an extractor, but that's a possibility if the other courses of action fail.
Old 09-03-2012, 01:34 PM
zeroptzero's Avatar
in order to provide an ending to this thread the OP has repaired his valvecover.
Old 09-04-2012, 02:00 PM
chris_barry's Avatar
If its really stuck take the cover to someone with a welder and weld a dag off the top of the broken bolt. You can then grab this with side cutters and remove the stub.
Take it easy when reinstalling as you could start a perpetual loop if you snap another one.
Old 11-12-2015, 12:19 PM
Wojofoo's Avatar
What extraction kit did you use?
Same thing happened to me on the last bolt today
Tried pliers on it but it didn't budge.
Also what size bolt did you get?
Old 11-12-2015, 12:27 PM
jkelley's Avatar
Just look at the replacement bolt size for the OEM bolt on majestic. the bolt extractor kits will tell you what sizes are in them
Old 11-12-2015, 01:07 PM
cleenyc99's Avatar
you have enough to grip with vise grips or small chisel and hammer. worse case have someone weld a nut but use a welders blanket to cover everything the sparks will leave burn marks. pls don't drill this you will f up the cover and not so tight next time lol.
Quick Reply: snapped bolt on ignition coil
