Smoking S2000s on track at FC04
There were several cars on the track at FC04 that were smoking coming out of turn 7 on the downhill section only. Once they started into turn 8 the smoking stopped. This seemed to happen every lap on the same cars but only in this one spot. This was not minor smoke this was a huge cloud but only briefly. Anyone know what the cause and solution to this problem would be? I am glad it wasn't my car but I am curious as it seemed to affect about 6 or 7 cars and seemed to get worse as the day wore on and the speeds increased.
1 Post
The oil moves to one side and has no time to return back on time.It happens to me as well in one corner only on our local track and my Spoon buffle oil pan is already on its way.
So its oil starvation then. Does it affect some more than others, because only the same few cars were doing this? Or is it that the smokers were being driven harder causing the oil starvation? I wonder if this affects the MY04s as well as pre04?
The solution is to install an oil catch can.
It is my understanding that the MY04's still see this problem, although the valve cover was slightly re-designed (presumably to help with this problem, but I'm not sure).
1 Post
The oil level may also have something to do with whether or not this occurs (although I'm not certain of that). Higher oil level may make it more likely to occur. Also, it seems like certain driving techniques cause it to occur more frequently.
Smoking right handers are not too common.. I have noticed it happens most often to drivers that do not heel toe.. I would guess a downshift before the turn drives the revs up pumping oil just in time for it to get moved over to the PVC.
1 Post
Race Miata
04-04-2006 10:21 AM
