Smoke from Vtec soleniod / tct
I just swapped out my cylinder head and as i went to start the engine after putting everything back together i noticed the engine started smoking, so i shut it off right away and went to see if I could find what the source of the smoke was. I pulled the valve cover but did not see anything abnormal. I traced the smoke to the area around the vtec solenoid and tct.
I appreciate your help.
here is a video.
http://youtu.be/pjll-yAHHqU
thank you.
here is a video.
thank you.
Hard to see what is going on in the video, but it looks to me as if it is just smoke coming from the exhaust header, probably just burning off oil and grease from when you reassembled the header to the exhaust ports on the head. It will eventually burn off all the residual oil and quit smoking if I am correct.
