Smoke from my exhaust on my ap1
Old 10-04-2014, 10:19 AM
woodywoody45's Avatar
Default Smoke from my exhaust on my ap1
My buddy was driving behind me and told when i rev up into the higher rpm a little black smoke comes out followed by white smoke.. Im not sure why its doing this?
Old 10-04-2014, 10:30 AM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
Engine was fully warmed up when this happened? Sounds like rings and/or valve guides clearance is starting to wear. Did most of the smoke from the exhaust happen on acceleration or deceleration? Accel usually = oil rings. Decel = valve guides. Just a rule of thumb.
How many miles on the engine? You may need to go to heavier weight motor oil. For instance, 10W-40, instead of 10W-30.
Old 10-04-2014, 10:47 AM
117k miles on it its happening when im accelerating, im currently using 10w 30 oil full synthetic
Old 10-04-2014, 10:51 AM
How bad is the oil consumption? If it's less than a quart every 1000 miles, you are prolly ok. You can try 10W-40 and see if that helps the issue.
BTW... that white smoke could be steam --- are you losing water in the cooling system? If so, check the overflow reservoir for signs of oil-in-water. Can look like a smear of goop or chocolate milk shake appearance. Or if you remove the oil dipstick, do you see "chocolate milk shake-like deposits on the stick? This could mean a head gasket issue.
Old 10-04-2014, 12:31 PM
I do burn a lot of oil, i change it every 2000-2500 miles, and its very dark by the time i change it. My oil is clean right now when i take my dip stick out to check, im going to check my coolant when i get home and let you know! Thank you man, ill try 10w 40 this next oil change to see if i get a different result
Old 10-04-2014, 02:38 PM
I checked my coolant and it seems fine and my oil is clean, but i have a really dirty filter and a spec d tuning (ebay) exhaust, maybe that might have something to do with it?
Old 10-04-2014, 05:27 PM
Good that there is no oil in the water and vice versa. Sounds like oil rings maybe a bit worn. Sometimes, when cheap oil is used or good oil is left in the car way too long --- the oil ring get deposits on them and lose some of their elasticity. I remember some folks running red auto tranny fluid (like Dexron) through old BMW 2002's to help clean up deposits. Then, flushing the engine with a couple of changes of regular motor oil. Auto tranny fluid (the red type) has lots of detergents in it and low viscosity. So, it works its way into small ports and areas well & helps to clean out deposits.
Then sometimes, the engine's oil rings will free up after this treatment. To the point of sealing better. Just a thought anyhow.
FWIW... I redid several BMW 2002 and 2002Ti, many moons ago. This Honda S2000 is the most fun car I've owned, since those days. Lot of the same attributes.
Old 10-04-2014, 06:03 PM
Ryuu's Avatar
marvel mystery oil
owned one of them 2002's.. rusted to death.. ran great otherwise..
Old 10-04-2014, 06:21 PM
Yeah, Marvel Mystery Oil could work. ATF works. At least, I've seen it work on a few engines. Really, it just delays the inevitable rebuild.
It was a sad day when I gave up my two 2002's. But, it was my introduction to Acura and Honda's great reputation.
Old 10-05-2014, 04:56 AM
Slowcrash_101's Avatar
A little blueish/white smoke when vtec engages is normal, as long as you're not billowing clouds I wouldn't worry too much. When was the last time you did a valve adjustment? Black smoke is from running rich.
Quick Reply: Smoke from my exhaust on my ap1
