Smelling gas from inside cabin
Old 09-19-2012, 10:49 PM
  #21
crisskro's Avatar
Glad to see I was right, cheap fix I also had to do
Old 09-20-2012, 06:23 AM
  #22
bsconz's Avatar
I am still having this same issue...but it's definitely not injector o-rings on my car.
2007 with 28K miles
It's alwaays hot here in Tucson, AZ so rule that out for me.
I seem to notice the most after 2 good long drives after a fill-up (so the tank is at about 3/4 full). When I get home from work the gas fumes are so potent I feel like I could get high in my garage!
Here's what I've checked so far:
-injector rail and o-rings (no leaks or wetness)
-fuel supply and return coupling connections inside engine bay (brand new condition, no wetness)
-lines under the car running along body towards rear (look brand new)
-gas cap is on tight
Here's what I haven't checked:
-rubber gasket inside gas cap (will do this at lunch)
-filler tube vent lines
-fuel sending unit
-quick disconnect fitting at fuel tank
-EVAP valve
-Fuel Tank Vapor Control valve
Old 09-20-2012, 03:19 PM
  #23
s2k-tilldeath's Avatar
2007 with 28K miles
-fuel sending unit
-EVAP valve
Yeah mine was so bad I thought I was gonna pass out. I have no idea about the fuel stuff on the car. I would just turn my key to the on position and gas would be squirting out of the injector area like an artery got cut lol. Just take it into a reputable shop to get looked at. You can just have them tell you what it is so you can fix it yourself if you want. Let me know what happens.
Old 09-21-2012, 02:11 PM
  #24
silvermonster's Avatar
keep us posted bsconz on your issue
Old 09-21-2012, 02:50 PM
  #25
seven7seven's Avatar
Glad I ran into this post, I myself have unfortunately ran into this same problem today. Please keep us updated on this issue.
Old 09-21-2012, 10:03 PM
  #26
Check your o-rings.
Old 09-22-2012, 10:32 AM
  #27
how can you check the o-rings?
any other symptom you experience beside the smell?
Old 09-22-2012, 11:55 AM
  #28
I don't know. I took my car to a very reputable s2000 shop around here and that's how I knew it was the o-ring. When I first saw the gas squirting out of the injector (right side of the engine) I thought it was a bad injector. As of now, I still smell gas a little when I get in my car. But that's just because the gas got on some stuff under the hood. You might be able to find a DIY somewhere on this site or google.
Old 09-25-2012, 07:22 PM
  #29
anyone know how to check the injectors?
would a bad injector cause the car to run rich or lean?
Old 09-26-2012, 05:38 AM
  #30
4forall's Avatar
Yes it could cause the motor to run rich or lean but not to the point of smelling raw gas fumes. Of course if your injector had a hole in it you would smell raw gas.
I would just turn the key to the ON position so the fuel pump is on and trace the whole fuel system under the hood and check for leaks.
Quick Reply: Smelling gas from inside cabin
