Small Leak Near or On Tranny
Old 08-01-2007, 03:56 PM
  #61
Slows2k's Avatar
Pretty much use the special tool # and install the seal. It takes a bit more finesse to do it right.
Old 08-03-2007, 08:49 PM
  #62
Tel1sps's Avatar
It makes you wonder why this is happening. Was the seal just defective or is there a bering issue also?
Old 08-03-2007, 08:54 PM
  #63
Slows2k's Avatar
It's not a common issue, 3-4 cars posted out of thousands sold. I'd have to see the leaking seal to tell why is was leaking.
Old 08-04-2007, 09:13 AM
  #64
Tel1sps's Avatar
What has been the cause on the ones that you have already seen?
Old 08-04-2007, 09:30 AM
  #65
Slows2k's Avatar
Improperly installed, the seal lip was rolled.
Old 08-04-2007, 10:29 AM
  #66
Tel1sps's Avatar
Were these untouched transmissions? If so then they were installed incorrectly from the factory.
Old 08-04-2007, 03:32 PM
  #67
jyeung528's Avatar
probably since they moved production back to suzuka, they don't have the elite selection of honda engineers that they used to have at tochigi. my speculation.
Old 08-05-2007, 03:22 AM
  #68
jzz30's Avatar
what!! engineers are assembling these cars now? explains the leaks!
Old 08-05-2007, 02:22 PM
  #69
S2KenC's Avatar
Yes, mine was an untouched transmission from the factory and I started noticing my leak at around 20k miles or so.
Old 08-05-2007, 06:19 PM
  #70
Tel1sps's Avatar
Mine started with 20K+ miles also... What is bothering me is that usually if a seal is installed incorrectly it leaks right away. Strange that it would take over 20k miles to start. The good news is the leak goes away after a new seal is installed correctly, so the leak is not due to anything else. If you hit 50k without any reoccuring leaks then you should be good.
Quick Reply: Small Leak Near or On Tranny
