Small Leak Near or On Tranny
Old 05-18-2006, 03:03 PM
Slows2k's Avatar
Both seals have been known to leak, the main seal is most likely. Make sure the clutch disc didn't get oiled up.
Old 05-19-2006, 06:34 PM
labratodd's Avatar
I got the same problem a month ago. Got it fixed at the dealer; they replaced PN 91216-pg1-005. Mime is an 05 with only 7000 miles on it when I found the leak.
Old 05-20-2006, 04:27 PM
RadioZero's Avatar
the above posted PN describes a Oil seal but it doesn't say where it goes?
Old 05-20-2006, 04:35 PM
Slows2k's Avatar
The rear main seal goes around the end of the crankshaft, behind the flywheel.
Old 05-20-2006, 05:29 PM
hatch4raceb16's Avatar
If that starts leaking, does this require motor disassembly or just pulling the trans and clutch and replacing that seal?
Old 05-20-2006, 05:41 PM
Slows2k's Avatar
Pull the trans, unbolt the clutch and flywheel. Then yank the old seal, and drive in a new one.
Old 05-21-2006, 03:37 AM
RadioZero's Avatar
this is an expensive repair job for honda to pay if its a warranty claim. why wouldn't honda design a permenent fix for an important seal?? stupid IMHO.
Old 05-21-2006, 05:35 AM
Slows2k's Avatar
There isn't a design problem with the seal. They are 1 piece seals that don't leak unless they get old and brittle, or they where cut or rolled during installation.
A 2 piece main seal like those commonly used 20 years ago leak much more
frequently.
It's pretty bold to say there is a design problem when you don't know where it goes and what it looks like.
Old 05-21-2006, 05:57 AM
Banned
Jasonoff's Avatar
[QUOTE=Slows2k,May 21 2006, 09:35 AM] It's pretty bold to say there is a design problem when you don't know where it goes and what it looks like.
Old 05-21-2006, 06:08 AM
SpitfireS's Avatar
This is completely off topic, but...
Jasonoff Posted on May 21 2006, 03:57 PM
I learned yesterday if you swap an AP1 rear end with an AP2 it will give you a closer 1,2 gear and taller 5 and 6.
How would a rear end (differential only as I understand) have an effect on a gearbox?
Now if you think of a "rear end" all the way up to the flywheel & clutch.. you would make sense.
Quick Reply: Small Leak Near or On Tranny
