Small Leak Near or On Tranny
Hello folks. First off my car is a 2005 model. Currently has ~19,500 miles on it. 100% stock. No mods whatsoever.
I just noticed after work that I'm developing a small leak on or around my transmission.
Small puddle under my car right underneath the tranny:
Jacked up the car and noticed a small drip right under the tranny where it mates up with the engine. If you look closely at the picture, you can actually see a small drip forming.
Looked a little further and noticed that my Clutch Slave Cylinder was half covered in oil:
Checked out my clutch fluid resevoir and it appears that theres ample fluid in there:
Since the fluid on my floor is oily brown, I don't know if its transmission oil or clutch fluid oil. Do you think that maybe my clutch slave cylinder is bad and its leaking onto the transmission and then onto the floor? Now that the car is just sitting, the dripping of fluid has stopped.
Any comments, suggestions, word of advice? I'm taking my car into the dealership tomorrow.
Any replies are welcomed. Thanks in advance!!
Kenny
Kenny
That looks like your hydraulic actuator is leaking. You can see the fluid where the rubber grommet meets the tranny. Have you checked your tranny fluid level?
If the fluid has a grippy texture to it, it's brake/clutch reservior fluid. Your tranny fluid shouldn't be that dark either. Looks like it leaked for a bit and slowed down.
If you have time, clean with spray brake cleaner, then spray with a talcum-type spray, and trace the path of the leak.
Sometimes it's better to have a leak localized before you go the mechanic (unless it's Billman).
Regards,
BD
Regards,
BD
Update
Just got back from the Honda dealership and the technician and service advisor stated that the probable cause of the leak is a possible failure in the rear main & input shaft seals (Slows2k online diagnosis ).
They're ordering the following parts:
91214-PCX-003 (oil seal)
91216-PG1-005 (oil seal)
Looks like my car is going under the knife. Since the parts won't arrive till late tuesday, they had me pick up the car. They told me that since its a small leak, I'm okay to drive it for now. Just to err on the side of caution, I'll just let the car sit in my garage till my wednesday scheduled appointment.
Anybody experience these types of failure? Diagnosis sounds about right? Thanks so far for the responses. Much appreciated.
Originally Posted by S2KenC,May 18 2006, 10:45 AM
Update
