Sludge in intake manifold
Normal. It's from the PCV flowing back into the intake manifold. This is why a lot of people use oil catch cans to "catch" the oil vapor, so it's not routed back into the intake tract.
Cool.
I should pick up a catch since I am turbo and track the car as well.
What would be good to use to clean the manifold when its off the car(cleaner type).
Chris E.
Chris E.
I think you could safely use a brake cleaner, but one of the Throttle Body cleaners will likely be safer, as it is designed to clean stubborn carbon-based deposits without stripping coatings that are on most TB's.
Other than cosmetics, is there any downside to the small buildup of residue in the pics?
BYW, I am using Lube Control (a powerful anti-oxidant) in my oil on the TL and S2000 - it has been proven to be "safe and effective" with no downsides - and everyone knows I am not an additive freak.
BTW, and off-topic, our Company is building a new $350M Research and Technology Campus, which my Team will be supporting for IT and Eng'g- 36 SOTA Labs - and new toys galore, including brand new SEM's! Yippee! More to follow. I am holding off early retirement to see this project completed, in 2007 - it is ine city block long, and will house 600+ scientists.
Originally Posted by hondamanwill,May 10 2005, 10:18 PM
Honda makes a killer throttle plate cleaner that works great. I'd try that. I'll get the part number at work tomorrow.
I plan to put in a thicker head gasket and will clean it out then.
Originally Posted by f20kills,May 10 2005, 09:00 PM
Sounds good
