Slight Vibration - Occurs When Taking Off
Old 03-20-2014, 07:43 AM
Lord09's Avatar
Yes, definitely not bogging or not giving it sufficient gas.
I'm still baffled why this would only occur once when initially taking off from 1st and then no more.
Initial signs of CV cup where? I thought wear would present itself constantly when driving?
Old 03-23-2014, 06:46 PM
slalom44's Avatar
Try letting off the clutch at higher RPM. If that lessens the severity, you could be getting oil on your clutch, causing clutch chatter. A bad rear main seal might do this.
If it gets worse at higher RPMs, you should look closer at your motor and tranny mounts.
Old 03-25-2014, 10:53 AM
Lord09's Avatar
Vibration is the same even when I let off at higher RPMs.
Anyone else have any suggestions? It's not very troublesome since it only occurs once when initially driving, just very strange that it's not continuous.
That being said, I'm paying close attention to the feel of the clutch and I'm just concerned it may develop into a something more serious in the future.
s2kdriver80
06-05-2012 02:28 PM
Dumas2k
02-25-2011 09:03 PM
19wrath85
09-25-2010 06:43 PM
avallach
12-14-2007 10:36 PM
nightcrawler7188
05-09-2007 06:29 PM
Quick Reply: Slight Vibration - Occurs When Taking Off
