slight shifter play?
Ever since ive owned my S when I hold the shifter in neutral at a light or somthing I can twist it and it will twist ever so slightly side to side its more of a notchy feeling. Mine is an 03 with 50k.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
The white bushing on the end can get worn out, or crack if you haven't kept up with regressing the shifter. I paid $4 or something for the bushing that you can see in this picture, simply pry/take it off if it's cracked and replace it with a new one.
The reason I brought this up is I had a buddy with a 95 civic with lots o miles and he had no play in his? I did figure this was normal however, its not excessive or anything thanks guys
