Slight hesitation on low rpm
Hey guys I have an 06 s2k with 3800 miles. The car has a very slight hesitation at around 2k rpm to 3k rpm. It seems to only occur in first gear when going wide open throttle.
For the record I will be bringing the vehicle in for the dealer to check. I'm making this thread to see if anyone is experiencing the same problem.
Possibility it might be the map sensor problem (just apply zip ties around that map sensor >>located on the manifold<<, but im not too sure if it was a 2004+ problem) because what happens is if you press on the throttle, that thing slightly "hops off", or your engine is cold. Make sure your engine is warmed up so you get a smoother ride. Try this and tell us how it goes.
Originally Posted by nuklearmaniac86,Jun 12 2008, 03:52 PM
How hot is it there? Stock intake? Could be heat bog?
For what ever reason when i arrive at the dealership, I couldn't duplicate the problem for the tech to see. The service manager inform me that my warranty is still good until May of 2009. Its such a small issue, I'm just going to drive the car for now. If the problem worsen I'll just head back to the dealer.
It's a common thing. Mine does it, I try to work around it. From what I've read here, it's in the fuel map. You may find more if you do a search.
It's supposed to go away with the Hondata re-flash. I'm hoping that's true... re-flashing soon I hope!
