Slight chattering under low acceleration from rear end
Hello,
I just recently purchased an 00' S2000 this weekend. The car currently has 48,000 miles on it. Overall the car is in great shape, and runs awesome! My only "concern" is I can feel a slight chattering from the rear of the car under light throttle. For example, cruising at 55 - 65 and I slowly roll on the throttle, I can feel some type of "jerking" from the rear end. No noises or anything. Now its not that bad, and it doesnt do it at higher rpms. Mainly just in 4th - 6th gear at lower speeds. This may just be me not being totally use to this car yet, or it may be some type of issue. It DOESNT do it at higher rpms or when I get on it. Is it possible maybe I am just to low on rpms for that gear? These cars are so different from the previous evos and subarus ive had. The rev range is larger, so I was thinking maybe its because im overloading the car being in a higher gear, at lower speeds?
Another question, ive done alot of reading but cant find an exact answer. Is it completely normal for these cars to have almost a "flat spot" in the range of maybe 3000 to 4500 rpms? Just like im waiting on it to get going! Again, it very well could be me just not being use to it. A second gear pull, it will feel somewhat flat up until around 5k rpm, and then it comes on. Normal?
Thanks for the info, and again any info is appreciated!
Rear end noise sounds like play in diff, maybe?
Flat spot could be valve adjustment, spark plugs, loose timing chain?
Congrats, on the new car.
Hello,
It may be coming from the rear diff. Yes. But I'm not hearing any noise. More so just feeling it a little. But it's not at all times. Just under heavy load. Or slight throttle input when in 4-6 at slower speeds. And as far as the torque goes it's hard to say. It's smooth, it's not cutting out or anything. And It pulls great when it hits v-tec obviously. It may just be me over thinking it also. But it just seems flat until around 5k or so. Then it takes off.
zeroptzero
11-05-2009 03:36 PM
