A slew of problems
A slew of problems
Sup guys, have a few problems with the S unfortunately.
1st thing I have a oil leak, and narrowed it down to the vtec solonoid gasket, so I'll have to replace that.
But now I'm noticing ever so slightly decreasing coolant in the external reservoir. To add to that, whitish smoke emits from my exhaust, albeit not all the time but occasionally. could it be head gasket?
Also I checked my spark plugs too, as I read somewhere that could indicate coolant leak.
I only managed to take a pic of the front most spark plug before it started to rain
1st
2nd
3rd
4th
1st
2nd
3rd
4th
If you have white smoke especially at startup and you're losing coolant, you likely have a leaking head gasket. Other symptoms include:
- Black greasy residue in your coolant reservoir
- Fluid level in radiator going down (checked when cold), but not in the reservoir
- Engine overheating, running hot
- engine sputtering at startup
