slave cylinder RUBER boot bURST
Old 06-11-2007, 09:51 AM
inactiveuser1114's Avatar
Originally Posted by photown,Jun 11 2007, 04:21 AM
hi guys, I am trying to grease up #1. Do you think I can manually remove #10 from #1. If so How should I do it?
Thank you and this community rocks.
VH
#10 and #11 comes right out just slip 11 out, after that #1 stays inside the cylinder. how do you take it out.?.. i have no idea
Old 06-11-2007, 11:03 AM
mikey k's Avatar
Originally Posted by Krenath,Jun 11 2007, 06:31 AM
Get the AP1 slave cylinder so you don't have to worry about fighting with the delay valve again.
Use a dremel and cut the guide pin down so it's short enough to fit in its notch on the AP1 slave cylinder.
That's my plan!
Old 06-11-2007, 05:52 PM
Ok slave installed back in business ...test drove it , clutch feel is quite weird.... releases way too low and it has play on top is this normal? why would this be?
car is an ap2 with brand new ap1 slave cylinder and new HG DOT3 fluid... comments? experience? advices? idea why this would be? thanks
Old 06-11-2007, 06:21 PM
Slows2k's Avatar
Air is still in the system, you need to bleed it some more.
Old 06-12-2007, 07:03 AM
got you thanks thats what i thought
macr88
Drivetrain
03-28-2012 04:59 PM
06gpws2k
11-03-2007 04:36 AM
06gpws2k
06-06-2007 04:10 AM
B SweepeR B6
10-25-2006 06:21 PM
AEsco48
03-16-2006 01:00 PM
Quick Reply: slave cylinder RUBER boot bURST
